Rebuilding transfer case pto
Jeepsinker
470
Dry Creek, Louisiana
For those of you who may need to rebuild your transfer case pto:
Front and rear bearings: Timken #342
Races: Timken #332
output seal: T.b.d when I get it cleaned up and cross the numbers
mounting flange gasket: Surplus, same as t-case bearing cap gasket.
Mine sat for a very long time unused on the truck it was on and the bearings had locked up from rust caused by accumulated condensation, much the same as the Garwood winches do.
