- 66
- 1
- 8
- south east louisiana
I checked all the wiring and voltages as instructed in the TM. I read many alternator threads including the sticky.
I initially found the diode trio was bad and they indeed tested bad on the bench.
I replaced the voltage regulator, diode trio and rectifier. The brushes are good and the winding checks good with a meter.
The alternator only puts out 11.5 to a bit over 12 volts.
Any suggestion are appreciated. Thanks in advance.
