Recentered PLS Trailer wheels for the deuce
junker42
Pacific City / Oregon
Say Young Gun I have a question for you. If it's your trade secret or something forget it but did you have to machine any material out of the center of the HEMTT wheel so the deuce bolt pattern would fit through without any interfearance. I have the equipment to machine the centers but my lathe/mill is not big enough for the wheels if I find some I can aford. Again it's cool if you don't want to answer. Thanks
YOUNG GUN
10
Sherwood, Oregon
The wheels I recentered are actually Oshkosh PLS Trailer wheels, NOT HEMMT wheels.
I was mistaken myself at first because the 2-piece type pictured look very similar to HEMMT style.
The PLS wheels actually work better than the HEMMT IMHO, because you don't have to modify the wheels in any way if you make the plate how I did, and you can securely bolt them together instead of welding.
I could be wrong about the HEMMT wheels, but I do believe they have to be modified.
YOUNG GUN
10
Sherwood, Oregon
Yes, the pilot hole diameter of the HEMTT wheel is 8.75", while the Deuce hub flange is 11" O.D.
G.
The HEMTT pilot is the deuce bolt pattern C-C, they would certainly need to be modified.
The PLS wheel pilot hole is barely big enough to fit over the deuce hub flange, so they are a perfect fit.
I've read many of your posts Gringeltaube, and you seem to be EXTREMELY knowledgeable about all the different wheels.
So, which is correct... HEMMT or HEMTT ?
Nevermind, maybe that was a stupid question, but I think I've seen it both ways.
It's HEMTT.
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
Heavy Expanded Mobility Tactical Truck.......
(Thanks for comments but I only know that I don't know much...:smile:)
G.
Beerslayer
55
Tualatin, Oregon
I come down to Pacific City regularly but haven't seen a deuce. I suppose it is camouflaged and just blends in with the greenery.
