Recovery points
G5TS
Tampa.
Getting ready to get the truck on the trail but wanted some clarification on the recommended recovery points for a kinetic rope and where I can attach a snatch block off of the HMMWV.
I have tear drop shackles, front clevis, Sherpa winch, and a h1 style hitch that is bolted to the frame and Airlift bumper.
Anyone have experience in this?
Coug
4,764
Olympia/WA
The teardrops are securely bolted to the frame. MUCH stronger than just about every civilian vehicle's recovery points.
Not sure which model this decal is from, but went out and checked my M1123 and it rated the front and rear shackles (teardrops) at 16,400 lbs.
The only thing I advise is if you get into a spot where you're severely stuck, and using more than a single winch block to multiply pulling power, is get something to use as a bridle between the two shackles. I have a 10' 1" kinetic rope for this purpose. Not really good to use kinetic ropes and winches together, but as a bridle setup it's way overrated and won't be stretching much.
I'm not sure if it would happen on the HMMWV, but I've seen civilian vehicles that pulled too hard on just one side and tweaked the frame out of alignment. It's less likely to happen when using the kinetic rope, but not impossible.
Coug
4,764
Olympia/WA
As for rear recovery point, because you have the airlift bumper, I'm not sure if going to the pintle on the airlift (if you have it) would be any stronger than going to the teardrop shackles.
The 2" receiver you have would be the last thing I would try to connect to. It would probably do fine, but the teardrops are right at the frame rails, so less chance of messing anything up.
Coug
4,764
Olympia/WA
I did find that about a decade ago someone was selling teardrop shackles non-military sourced that they said were rated at 25k lbs.
The shackle itself isn't the weak part, and with how close it is to the frame I wouldn't worry about using it, other than overdoing it and tweaking the frame, before anything actually broke.
  • Like
Reactions: 98G
