this ac is wearing me out, none of speeds are working now. Sometimes when I turn it on low and middle work but never High, I have replaced switch, replaced resistor, replaced blower motor, basically have replaced everything inside it, with exception of two relays which i am having trouble locating replacements. Looks like I can buy a new old stock unit online delivered for $200 bucks, think its worth it at this point? Also assuming the 60 amp alternator puts off enough amperage for the ac? If not where can I pick up new larger alternator?
Should be in the blower box. It will be somewhere between the switch and the blower unit. On my MCC unit it is screwed to the blower unit.
You need to do proper diagnostics before going that far though. Take your test light and check to see if you have power to the blower motor on high, if yes, replace blower motor, if no remove the main fan switch and check for power out of the switch on the high, if no power but there is power to the switch replace the switch, if yes then check continuity of the wire from switch to blower motor. if it's good locate the resistor and check for power to it and coming out of it on high. If the continuity is bad then you more than likely have a resistor in line as it is open and dropping power .
