Red Dot condenser right rear fender
sermis
17
Temple, TX
How well do the right rear fender Red Dot AC condenser work verses the condenser mounted being the rear curtain. I know they only have a plastic shield to keep the dirt, mud, and rocks out. I've heard both good and bad but haven really heard from anyone with first hand experience on then. Planning on adding an AC unit to the HMMWV soon but not sure on the condenser yet. Hat to lose the bed space with the condenser but don't want the fender mount if there are a lot of issues with them either.
Sent from my SM-G920V using Tapatalk
erasedhammer
56
Maryland
Another option is to get a civi condenser and mount it on the radiator stack. It's not too difficult and can be integrated into the red dot kits.
sermis
17
Temple, TX
I thought about the civi condenser. Need to look more but it's $$$. Fender units I've seen around $200 but civi Seam to be close to $900.
Action
1,552
East Tennessee
Reddot didnt make the fendee condemsor. The fender unit is a factory installed part. Reddot is aftermarket.
The fender part works good. I have it.
sermis
17
Temple, TX
A lot more searching. I have found H1 HUMMER condenser under $100 but the HMMWV ones are $900+. To me it simply looks like how they mount on the radiator stack is the only difference. And maybe hose connections. If heat starts to've an issue I could add an electric cooling fan I've never done an AC so this is new. Any ideas will help.
