redline water wetter - diesel version
BLK HMMWV
428
Pasadena California
It's been around for a long time.
There are 2 other manufactures of similar products
Purple Power & Lucas
I think any of them would work in the coolant system of a diesel or gas engine equally.
Running the water wetter in the aluminum radiator of my blown 66 mustang without mixing with antifreeze
I'm not worried about freezing conditions in. Ca.
Squirt-Truck
Master Chief
162
Marietta, Georgia
Works, good for 5/10 degree reduction (but not below the thermostat setting). BUT be sure hoses and clamps are in good condition and tight or it will leak...
911joeblow
68
Utah
Water cools better than coolant. Water Wetter allows for some lubrication of your water pump seal and other seals and has some anti-corrosives in it as well. It basically lets your run strait water when you wouldn't be able too normally. As mentioned this will not give you any freeze protection.
WARNING SELFLESS PLUG!!! Of course you could just get a Cooling Upgrade Kit and get all the befits it has to offer and not worry about cracking your block! https://paradoxbydesign.com/collect...oducts/hmmwv-humvee-cooling-upgrade-system-v3
Retiredwarhorses
3,893
Brentwood, Calif
Water cools better than coolant. Water Wetter allows for some lubrication of your water pump seal and other seals and had some anti-corrosives in it as well. It basically lets your run strait water when you wouldn't be able to normally. As mentioned this will not give you any freeze protection.
Just plain rediculous....I will leave it right there.
