BFR
Rocket Surgeon
- 2,331
- 43
- 48
- North Georgia
pics of it painted?
Cool on the ceramic paint coating. New info for me. For power, you got what 24V*60A=1440W so that inverter is great! Hope it will start the a/c reliably. Most will do a pretty big surge. You are right - it will be much better than no a/c at all.I am installing a 900 watt inverter to power the A/C unit. Unit draws 600 watts.
Here is the link to their web site:
Power Bright - 24 Volt Modified Sine Wave Power Inverters
I would not use the 12 volt to 120 volt inverter. You will end up damaging your batteries. I recommend you get the 24 volt to 120 inverter I mentioned earlier in this thread. It is very reasonably priced and will run the A/C unit without draining the batteries.good idea on the AC unit, I might try it on my m820a2, I own a 1850 watt 12 volt to 110 volt inverter, planning on trying that, it should power it, although I'm considering istalling a bigger alternator. I think the stock one is 60 amp at 24 volt, maybe that would be enough with four batteries.
It is a 3 phase pump for the liftgate. It is meant to be used when the truck is connected to a 3 phase power source - you don't have to run the engine to use the liftgate.I like your mods.
what is under your box on the outside of the frame rail on the passenger side?
For you no problem PB! We can make it work.Looking good GE. Gonna let you try it a few times and if the truck doesn't flame off or you don't get fried I will bring the M185A3 down for you to install the AC etc.
OK Buddy??
