Reduce Rattles
01GRANDER
56
Alabama
I know, hmmwv’s aren’t supposed to be quiet but what have you guys found that helps make their noise more bearable?
I just bought a roll of neoprene foam tape and applied it around areas on my seats and probably 1/2 of my rattles went away. It makes it a lot more bearable to drive around town with our horrible roads.
Coug
4,692
Olympia/WA
ear muffs.
More specifically:
I think I paid about $110 earlier this year on ebay. Batteries last a long time, I listen to books when I drive, and when on the phone the person on the other end seems to have no issues hearing me.
But to answer the question you were trying to ask, there are some guys that have done things like lizardskin and other products that insulate and provide some sound deadening (downside is you kind of have to disassemble the truck and clean everything REALLY good if you want the end results to be good and last). Using horse stall mats on the tunnel also seems to help a little, and also helps with heat.
01GRANDER
56
Alabama
ear muffs.
More specifically:
I may get some lizard skin to apply, any idea if you have to use a certain primer before applying it over aluminum or Carc?
I still have the wood over the tunnel, I am currently building a center console out of wood above it and then putting fiberglass over it, that should cutdown on a lot of the heat and sound from that area.
Coug
4,692
Olympia/WA
I don't know, but hopefully someone with some experience using it will chime in, or they might have mentioned it in another thread.
If nothing else you can check the manufacturer's website for what prep is required.
My understanding is they have several varieties. One for heat, one for sound, and who knows what else.
Andyrv6av8r
458
Spartanburg,SC
Generic Rhino Lining inside of the doors.
1 inch Armaflex padding all over, including under the doghouse.
And also 3/4 inch Horse Stall Mat from Tractor Supply in place of the wood. Highly recommended.
TOBASH
3,914
Brooklyn, NY
It rattles less if you don’t drive it.
Replace door seals and gaskets. Pad the rear hatch. HUGE difference.
