registration number?
two.fiveM35
11
Victoria , Texas
I am trying to licence my truck and they said i could have the option of just using the register number of the truck. Is that the number that is painted on my bumper and tailgate (see profile picture to the left)?
Thanks Eric
jimm1009
71
Louisville, KY
Examples are 04J01968 or NKO4J4 or 04M1934
The registration number is not the same as the serial number.
s/n examples: 0125-12465 or 0325-54398
Louisiana allows this too as does Indiana and a few other states.
jimm1009 [thumbzup]
1,191
Post a picture of your Dash Data plate, the serial number is on them, sometimes(depends what version tag and when it was made)
DDoyle
West Tennessee
If you will provide the manufacturer's serial number, there is about a 60% chance I can give you the correct registration number.
Best wishes,
David Doyle
jimm1009
71
Louisville, KY
The serial number should be stamped into the frame in one of two areas. With that information David and/or Carnac can probably help you.
Use a small steel brush and some MEK or Acetone and clean the paint in the area just to the rear of the steering gearbox mounting area and also just forward of the upper shock mount.
I personally would try the gearbox mounting area first but you should find the number and possibly the frame heat treat date too.
Don't use a grinder or a strong powered wire brush as you can actually damage the numbers. Use paint stripper and a soft steel brush kind of like a tooth brush that is available at Home Depot or Lowes or Stines.
I have a picture at home and if my wife can e-mail it to me I'll post it in an edit to this reply.
The numbers are not stamped real deep and are about 1/4 inch in height.
Let us know what you find.
jimm1009
Edit: Here is a PDF picture of the left front wheel well area where the numbers hould be stamped on the frame and a data plate for a 1967 M35A2 that has the serial number and registration number stamped into it.
The blank for serial number is actually the registration number but it came from the factory like that.
jim again
M813rc
3,782
Near Austin, Texas
http://www.steelsoldiers.com/conversations/9593-texas-former-military-vehicle-registration.html
In Texas, use anything you want, as long as someone else hasn't already used it. Note there are restrictions on the FMV registration, similar to antique plates (if your using a collectors/antique insurance policy, probably about the same).
As Runk said, you can use anything already painted anywhere on the truck, or you can make something up and paint it on there and use it. I know one guy who used TP18! It just has to be in letters and/or numbers at least 2" tall and "a contrasting colour" (ie green on black, black on green, white on orange, whatever, your choice). I believe it can be a maximum of 6 letters/numbers.
Cheers
CARNAC
The Envelope Please.
698
Corpus Christi, TX
In TX it ain't the registration number it's the bumper numbers. Bumper numbers are what is in your avitar picture. Registration number and serial number will be on the data plate on the dash on the passenger side.
TX is the only state I know of that will allow you to use the BUMPER numbers as your license plate.
Cheers
two.fiveM35
11
Victoria , Texas
Yes you are right, I may just us the bumper numbers after I find out how many digits I can use. I think I will go to the Military Museum one of these weekends and ask the guys down there how they register theirs.
mcv1964
Martin City, MT
Dash Plates - NSN & Reg # help
Can you or anyone else help me with my registration number and NSN number?
My vehicle is a 1951 M135, Serial # 3112
It was overhauled:
Pueblo C.D
Date: October 59
ODOM: 135391 or 13539
CARNAC
698
Corpus Christi, TX
The Stock Number could be obtained via the VIN INFO Thread. That's cause there were some older vehicles listed in there from 1971/2 era. I've found a few M38's and M715's in there in the past. It would be a very long shot to recover the registration number from there. It would have been painted onto the vehicle.
