Relay voltages? M1078
Xengineguy
831
USA Indiana
Hi I have a m1078 2001 a1. I noticed the other day all the relays in the fuse box are 12 volt. Looked thru the tm’s
a little but didn’t find an easy answer. Which relays are 24 volt ? Which are 12 volt? Fuse box far right of dash.
Thanks.
Ronmar
8,403
Port angeles wa
In the A1 they are all 12v coil, either 4 or 5 pin. If you look at the schematic, for all the relays that are controlled by 24V, there is a resistor placed in series with the coil to dissipate the excess(adapt a 12v relay to a 24v power source)…
Xengineguy
831
USA Indiana
Thank you! I didn’t notice the resistor in the schematic.
