- 1,653
- 1,669
- 113
- Nova Laboratories, WA
I see it's a popular mod and makes perfect sense.
I've spotted a couple universal reservoirs itself for like $20 on amazon, but I have some questions.
Normally, the MC reservoir is vented to atmosphere... Now, if you get a remote reservoir, and the reservoir now has a vented cap, that means it's not waterproof, and, due to laws of physics, you can't have a vent line AND a reservoir because fluid will fill up the vent line up to the level that the reservoir is at.
So, how does one deal with high water situations? Maybe a valve that shuts off the reservoir, and then just flush the reservoir when you're done doing high water stuff and refill with DOT5? Make a DIY fording kit and just push 1 PSI into the reservoir, to keep water out?
Thoughts?
I'm understanding that you don't want a sealed reservoir because if you do have a fluid leak at a wheel cylinder, fluid won't be drawn in to replace the air in the lines and it'll create a vacuum and more air will get sucked in from the leak, is that correct?
Thoughts?
