Remote brake reservoir
rustystud
3,313
Woodinville, Washington
1245.jpg This is my master cylinder with the "adapter' installed where the plastic reservoir usually goes. You can see the two lines coming out the top that go to the remote reservoir mounted on my firewall.
77 AMG
62
Owingsville, KY
Hey, rustystud. Quick question- If you are using the M/C like you have, then, a NON Air Force M/C bracket still works, yes? Since the overall height of the M/C doesn't change, correct?
rustystud
3,313
That's correct. The difference between the brackets is the mounting of the PTO shift lever. Since I don't have a PTO on mine I could use the old style bracket.
77 AMG
62
Owingsville, KY
THANK YOU to both of you! *off to the basement, to fire up the mill*
Hey, Rustystud... what did you borrow the M/C from? A mid 90's GM Topkick, by chance?
rustystud
3,313
What do you mean "borrow" ? It is the stock Master Cylinder for all Air-Force Deuces. The top adapter though is on several models of medium size trucks. Including a lot of Fords. I also know several GM trucks used it too.
77 AMG
62
Owingsville, KY
Slang term, my friend. "Borrow"- re: To take/ use from a different source than was originally designed, i.e. The M/C is question, I thought might have been from a Civilian truck, such as a GM TopKick series medium duty chassis, and that you had "borrowed" it to use on your truck. That's all. Either way, THANK YOU for sharing the information regarding the install.
rustystud
3,313
I am aware of the term "borrow" . I just was confused since that is the stock master cylinder for the deuce. I can see with that different top how it might have looked like a different master cylinder though.
77 AMG
62
Owingsville, KY
Fair enough. I was thinking that maybe there was a civilian version that might be easier to find. I'll try some more "Google FU" and see if that helps any....
