Removing Axles for Highway Driving?
SixSpeed
Banned
1,107
Tampa, Florida
Hey Guys,
Couple questions when it comes to pulling axles on the 5-Ton...(Looking for highway MPG on a long trip)
1.) For the rear axles, should I pull the front set, or pull the rear and remove the intermediate drive shaft?
2.) If you pull the front axle's & drive shaft...the sprag will think is it slipping and engage, is this correct? Would this damage anything, or does the sprag need to be disconnected?
3.) Would it be wise to make some sort of cover for the axles, say a piece of polycarbonate or something to seal them back up?
Any tips would be great. Thanks guys!
SixSpeed
Banned
1,107
Tampa, Florida
Truck has detroits, would have to pull both shafts.
Since I don't know too much about this, why is the rest of it a "huge pain"? Any advice much appreciated. Thanks!
pctrans
19
Bradenton, FL
Fuel consumption would be negligible. If anything, just pull the front driveshaft, in the event the sprague is locked up.
KsM715
142
St George Ks
I dont see any harm in pulling the front driveshaft. If the sprag engages it will just spin the front yolk.
If your worried about the spag after you pull the shaft you could cut the air off to the transmission to keep the sprag in neutral
jwaller
19
Columbia, SC
ah, you have lockers. yes you will need to pull both on the front tandem. it's a huge pain bc there are a lot of bolts, hard to get to and you will have an even harder time getting the driveshaft back in after you run it around. and as I've said you won't gain a single mpg out of the whole thing.
pulling and axle shaft is quick and easy.
  • Like
Reactions: art
M813A1
OKC, Oklahoma
It should be easy to pull the short shaft from between the rear drives and only drive with the front drive axle pulling and it should not effect the sprag and it should work as a 4x4 and give you some more mileage with less drag on the drive line and increase your mileage !!
powerhouseduece
Pasadena, Md
Start collecting the flanges for the front axles. Despline a set for the front and pull the middle axle axle-shafts and bolt the drive flanges on to cover the hub.
rosco
32
Delta Junction, Alaska
I did all this stuff some time ago - like along about 35+ years ago, for a trip down the Alcan to Dawson Creek in a M211. Pulled axels, had de-splined flanges for the front axle. While there, I got stuck, put all the stuff back, and came home w/stuff installed...... No measureable difference in MPG. I think were talking, close to the same kinds of trucks! My bet - No measureable difference in GPM, but it will keep you busy
Lee in Alaska
1,156
It should be easy to pull the short shaft from between the rear drives and only drive with the front drive axle pulling and it should not effect the sprag and work it would work as a 4x4 and give you some more milage with less drag on the drive line and increase your mileage !!
Two threads people should read before taking up that advice:
http://www.steelsoldiers.com/deuce-modification-hot-rodding/39811-thought-u-joints-tandems.html
http://www.steelsoldiers.com/deuce/38371-deuce-transmission-disaster-pics.html
