removing IP head - what am I missing
serial14
11
Albuquerque, NM
I've read all the manuals and all of the posts in the forums and I still can't figure out how to get the IP head off. I've located the scribed tooth on the head and the pointer inside the cut off cover and have lined them up. The fuel lines have been removed, and my pump doesn't have a oil valve on the head so I don't have to worry about that. The head will lift up about 1/16" - 1/8" but then won't come any further.
Am I missing something or do I just need to pull harder?
lavarok
33
Fellsmere, FL
You need to remove the fuel shutoff assembly from the side of the unit.
Follow the cable for fuel shutoff, remove the cover and the assembly from side of IP....the head will slide right off after.
serial14
11
Albuquerque, NM
How much of the fuel shutoff assembly should I remove? I've removed the cover so I could line up the gears. Do I need to remove the bolts that hold in the linkage?
lavarok
33
Fellsmere, FL
YES - remove the linkage bolts and slide the assembly out carefully. There is a small retaining washer too if I recall around the shaft of the assembly keeping it attached to the linkage.
blackwater1
ft myers fl
Hi Cranehead
My deuce has some fuel coming out the little hole in the head --shown in your picture.
What do i need to do to fix it?:cry:
I was going to try to get a picture -- but thanks to you we have it.
Thanks Mike
cranetruck
75
Meadows of Dan, Virginia
You will need to replace the O-rings of the hydraulic head. Also do an oil analysis of the crankcase oil, it probably has a high percentage of fuel ...
blackwater1
ft myers fl
Just take the lines and top off and ill find the oil rings? and are they special o-rings or will i be able to find them at an auto supply. thanks for the help
blackwater1
ft myers fl
What great info to keep great old trucks running --- cranetruck thank you!!
while your at it i can reply to a post but cant start a new one -- i sent a message about it to support 2 days ago but havent heard back --- any ideas?? :roll:
mike
blackwater1
ft myers fl
Well with the help of this thread -- I tore the IP head off to replace the 2 0-rings. It went as expected the 2 hr job took about 12:cry: ( big learning curve ) the first IP I have torn into.
So after removing heater ect. I start to remove injecter lines from head --- all the lines except one line (#3 had a rain cap on it) were rust welded to the nuts :roll: so I remove the lines from the injector --- struggle to line up tooth to mark --- remove hold down nuts and fuel lines ect. remove IP head -- I decide to remove stuck lines from head ( only had to straighten one some --so get stuck lines off and put them in some 30 min rust remover--- hours later still rust welded in place:twisted: Mean while I locate the larger o-ring right away-- but dont see the smaller one --- so tear into head to find small o-ring hmmmm --Oh there it is still in the housing -- lol -- put head back together. I drive 30 min into town to find o-rings (we are at our farm in rural Iowa not at our home in Florida). Go to Napa first -- no go-- then to big machine shop--- nope :roll: Third try I go to tractor dealer --yea they have the o-rings or at least they measure to specs.:wink: So its back with the booty -- I put rust welded lines back in the head -- and struggle to install head with lines attached:evil: Over an hour later i get the head on and the lines in the injectors:| I tidy thing up and get the wife to run the started -- without too much cranking we start to get fuel spitting out the not tight injector line and the engine starts to run -- I tell the wife to shut it off -- I tighten the injector lines and she hits the starter --hmmmmmmmmmmm sounds good -- dont see any fuel leaking:-D
I didnt run it hard but will tomarrow.
Thanks to all for the info and pictures
Mike PS Only fell off the truck once :razz: and one cut on the hand -- even with gloves on --lol
serial14
11
Albuquerque, NM
I still have all my injector lines off as I fix other things on my deuce. I have one injector line that has rust problems as well. I haven't been able to break the rust free yet either. I'm not looking forward to trying to put the line back on. I'll have to try rust remover.
cranetruck
75
I have found that's it's easier to get the compression fittings aligned if the injectors are loosened up a bit first. Don't force the threads, you should be able to get them started by hand.
