Removing oil gallery plug
Manstein
Chaplain Emeritus
331
Cartersville Ga.
I'm in the middle of a turbo install and I'm trying to remove the oil gallery plug. It won't budge and I have rounded the edges trying to remove it. Any suggestions?? Tomorrow I'm going to try to heat the plug and then try to move it with a pipe wrench. If that won't work I guess I'll have to try to drill it and extract it with a easy out. Anybody got any suggestions or stories on how they succeded?
dmetalmiki
2,027
London England
How did you strip that plug? what tool were you using? anywaze if you have a decent welder( machine and man!) weld a GOOD hex on there and remove it WHILE STILL HOT!! with a GOOD & good fitting wrench. AND BREAKER BAR>good luck. I did TWO that way!
1,807
I had issues with the turbo oil return hole. The plug from the NA motor was at a weird angle and a PITA. I later learned that it is 13/16" square, same as a budd thimble. I'll be ready for the next un.
Manstein
Chaplain Emeritus
331
Cartersville Ga.
Got it! I drilled a hole thru the center, inserted a jigsaw blade, cut it in 4 sections and then loosened it with a hammer and punch.
The turbo is now up and running. I noticed a big difference in low end torque improvement. It seems to top out and be a little more sluggish around 50-55 than before the timing adjustment. Oddly, it seems quieter with no muffler than before with the non turbo exhaust set up.
Overall, I'm glad I converted it.
