gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 788
- 113
- Cincy Ohio
Let us know if you have more questions.
Yea you to have a buddy to make this work! Preferably 2!We put the truck in 5th, high transfer and moved the entire truck. It can also be done in gear with a wrench snaked through a universal joint. You would have to get very lucky to line the marks up with the starter. We're talking, a truck in 5th moving almost 1/2 an inch to get things lined up. Also, don't think too much about the timing marks underneath the 4 bolt governor cover toward the front of the IP. They are going to be off to the left. Doghead put a good picture up a while back. Also, don't worry about where the crankshaft damper is, those marks are off a little as well. Just look for the scored tooth and maybe the red mark lining up with the triangle reference point. It helps to have a mirror as you can't really see through the inner fender and the steering box keeps you from looking upside down from the top.
The red/scored tooth on the HH is ONLY used for removing the HH. The marks on the dampener and advanced unit(disk under the 4 bolt hole window) are for timing the pump to the motor.We put the truck in 5th, high transfer and moved the entire truck. It can also be done in gear with a wrench snaked through a universal joint. You would have to get very lucky to line the marks up with the starter. We're talking, a truck in 5th moving almost 1/2 an inch to get things lined up. Also, don't think too much about the timing marks underneath the 4 bolt governor cover toward the front of the IP. They are going to be off to the left. Doghead put a good picture up a while back. Also, don't worry about where the crankshaft damper is, those marks are off a little as well. Just look for the scored tooth and maybe the red mark lining up with the triangle reference point. It helps to have a mirror as you can't really see through the inner fender and the steering box keeps you from looking upside down from the top.
