2tierradelfuego
- 0
- 1
- CT
I mounted hutchinson 20 inch split rims with XZL 395/85R20 with run flats on my imported Mercedes ex fire truck. I am planning on removing the run flat inserts, to reduce weight and to be able to insert balance beads and have a few questions:
1. I saw some videos on how to remove the run flat by basically pulling it out. This puts a lot of stress on the inner edge of the tire. Will this cause damage?
2. Is it necessary to insert beadlocks B3040 https://militarytires.ca/product/hutchinson-beadlock-20″x10″-for-tubeless-set-up/
3. Will balance beads work on these large tires?
Thanks!
Thanks!
