Removing the dash
darylwiz
Orange County California
I need to remove the dash, I have removed the gauge cluster, 2 bolts to the left that pass they the firewall, and numerous screws.
The bottom of the dash is lose I can bend it out and forward.
The top is stuck by the window, can someone tell me how to free the top portion.
Mogman
8,506
Papalote, TX
I believe there is one bolt through the firewall on the right side, not sure though and one bolt vertical on the right side bottom of the dash.
Other than that if you can swing it up it just "slips" out of the top after swinging it up, should not take too much effort.
Mogman
8,506
Papalote, TX
Yes, 4 bolts, two #27, one #21 (the right one I said goes through the firewall and one #28, the vertical one, it is in the middle not the right side as I remembered.
INFChief
1,344
New York
Just curious why you have to remove that.
Mogman
8,506
Papalote, TX
Looks to me like #28 holds a clamp, #22. I would say #27 and #21 hold it in.
28 also goes through part of the steering column mount, they do not show the others going through the firewall ether..
The same bolt also holds a cable clamp, that is a parts diagram not a service procedure.
Action
1,552
East Tennessee
I know. I only posted to show where the bolts are.
I would assume the steering wheel needs dropped and the dash swung out of the top groove, just like the duct over the doghouse.
