kapnklug
- 4
- 18
- spencer,ny
So I'm finally getting around to replacing my leaky valve cover gaskets, which are allowing oil to leak all over the exhaust manifolds and making alot of stinky smoke. It's going to be a real pain removing the intake manifold and injector lines, so I want to do any other maintainance while I'm in there.
I can't find anything in the TM's about adjusting the valves; do the rocker arms need periodic adjustment like on a gas motor? How does that work? And is there anything else I should do while I've got it taken apart?
