Rental Truck
marsman
-1
Maryland
Has anyone picked up 1m10a2 or A3 with a rental truck? If so how many can you fit into a 16 or 24 footer? I am thiking of bidding on one of each or at GL
hole
Alta Loma , Ca.
You could probably shoehorn two if your creative, but I dont recall ever seeing any D rings in a rental van for the binders. (at least any van/box truck I've rented) BTW, 101's or 105's? Kinda hard to tell from your first sentence "1m10a2 or A3"
hogtruck
Edinburg, MS
FWIW, most Uhaul trucks have 2 in ball welded in place. Some of the newer trucks have a receiver tube just to the side of the ball hitch. Have pintle hitch in your hot little hand when you go put eyeballs on the vehicle.
gunboy1656
22
Beaver Falls, PA
If your going to rent a uhaul truck to bring the trailers home, What are you going to be towing them with in the first place? If you have a truck to tow one not 2 then why not just rent a 16' trailer? (would be easier to load and unload)
A
A/C Cages
Guest
Dont forget if you are towing any of them, Lights dont always match up from Civy to MVs. A simple set of tow lights come in handy.
Even a cheap pair from Harbor Freight for only $9 will work.
Chief_919
100
Western NC
I can tell you that 2 M101's will fit on a rental car hauler trailer from U-Haul, had to do that when I noticed a wheel bearing that looked bad the night before a scheduled recovery.
