Reommend change all fluids
Gruemeyer
Greenfield Indiana
HI .
my M109 just recently arrived from auction.. Would you guys recommend that all the filters and fluids be changed?
PS. I think I saw a filter kit Deuce for sale some where on line
smoke
89
oxford,pa
I would go through and change all the fluids and filter. It's peace of mind and a good start point for you to keep tract of it. Plus you don't know how long it been seating or serviced last. I would also drain fuel tank and flush it. And seen you are in there check the rubber hose on the fuel sending unit. Plus check the brake fluid. Just my2cents
4x4 Forever
Emerald Shellback
That's your call, but I would suggest changing all filters and fluids. That way you will have the piece of mind of knowing what you have and/or finding anything wrong.
While your at it, you need to do a complete PMS on the beast...
The filter kit is in our classifieds.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Going through the axles should be first on your list. Check for bad bearings and make sure the brakes are in good working order. Those parts can cost you the most head aches.
KsM715
142
St George Ks
That would be "PMCS". Preventative Maint. Checks and Services
PMS is whole other headache in its own right
ryan77
56
Cary IL
I bought a complete filter set for mine off a member here! Comes with all of them and the seals! Makes it easier and there quality filters!!
