Repair/maintenance Assistance needed OR
rolling18
75
Portland, OR
hands on instruction (paid) within reason...
replacing front seals and boots.
how much would it cost me to have someone to show me how?
I can travel within in Oregon or Washington or someone can come to my place
I would like to do this on a weekend sometime soon and have most of the tools and parts except the wheel nut socket
Thanks!
Marc
1,168
Moved thread and changed title(exclamations are reserved for real time emergencies).
rolling18
75
Portland, OR
I will keep studying it and also take a look at the other one and my offer still stands it would take a lot last time with someone who has done this before killing me
brianp454
11
Portland, OR
Marc
Hey we met at the Chehalis event last summer. I'm the guy with the other desert tan truck similar to yours. When you arrived I asked about the KVM lockouts.
I helped my buddy do all three of his axles with the whole brake system at the same time. Now we have my truck apart and are doing the front (replaced the rear seals over last Summer). I was shocked on my truck to find how bad a shape it was in. I find that the time spent doing teardown, cleaning, etc. can really drag on. Anyone can do a wham bam TY MAAM, but another to do it right and have confidence that it will be in good shape and safe for a long time to come. I have all of the tools needed and 6 extra wheel cylinder rebuild kits. I'll PM with my number.
-Brian
rolling18
75
Portland, OR
Brian great!
yes i remember.. was great meeting you!
and yes thats why i want to do the work to learn as im sure i will need to in the future and help others as well!
firedog104
North Idaho
Just did mine recently, wasn't bad at all. I've done bearings/seals several times on older pickups, this is no different, just bigger. Prepare LOTS of grease rags if you want to clean things up good, along with disposable latex gloves. I didn't have the 8 sided socket, but I could see someone had used a cold chisel to loosen/tighten the nuts. Not the best way to do it, but since I didn't have the wrench I followed their lead (let the flaming begin). The nuts are easy to access after the fact to double check the torque when i get the wrench.
Also, since I didn't have a large enough gear puller and didn't want to buy an exhaust pipe flange tool and slide hammer, I just used a 6 foot long 3/4 " pipe from the other side. Worked great and didn't cost anything. I also used about 1.5 gallons of grease to fill the knuckles real well. Probably overkill but my shafts aren't the u-joint type so I figure more is better as long as it isn't splooging out around the rubber boots.
