Replace anything extra while engine is out?
Awesomeness
1,518
Orlando, FL
I'm going to be swapping out the engine in my M1078, because of the cracked block. The replacement engine is good, but also out of a mid-'90s truck. Is there anything I should go ahead and work on or replace, on the new engine, while it's out of the truck and easy to access? Seems like it might be a good time to replace some gaskets seals that go bad with age, like the rear main seal on the crankshaft, or similar.
Any advice?
Awesomeness
1,518
Orlando, FL
Thanks, if I start using it for long hauls I'll definitely consider that. For now I just use it around town, and I've got this MTV engine coming.
Suprman
696
Stratford/Connecticut
Rear seal can't hurt but it takes a special tool and you don't want to find out you did it wrong when the truck is all put back together.
Awesomeness
1,518
Orlando, FL
True, though I could always talk to the guys down at the truck repair shop and see if I could pay one to come over with the tool and do it. Better than having it go, if that's common, and have to pull the engine out again.
