Replacement oil pressure switch for A0
coachgeo
3,461
North of Cincy OH
Napa part number. 35$
Cut the wire/plug, crimp on terminals.
Put some medium loctite on the screws.
A pain in the butt to get to.
Don't forget to disconnect the batteries!
have you been refering to the parts spread sheet that is a pinned/stuck to the top of this forum?
and same question as earlier.... you have installed this and all is going good now?
of course also thank you
coachgeo
3,461
North of Cincy OH
No. I didn't look.
I tend to do my own thing.
Switch is installed, same 15 lb normally closed switch. The alternator did not notice that it was no longer leaking oil.
the alternator does not come on (excite) till the oil pressure shows the engine is up and running (couple things are on that circuit) ...... therefor it is important pressure sensor and switch fall in the parameters of the oem. Thus the questions.
MrMikey4026
417
Eatonville Washington
No, pressure sending unit just operates the gauge. The pressure switch, turns on the low oil pressure light. Opens who knows which relays, disables the starter, turns on the alternator. Neither has a direct effect on the other. They are both screwed into the same tee.
