Replacing Air pack M813. Fitting help
zxmedic
Canada
Working on replacing the master cylinder and Air pack and using the TM. I am having some issues with the air fittings that go to the air in specific the one in front of the top bleeder mine seems to have had a check valve in it is this right or like the TM shows only a 90 . Or is that Part number 2 page 263 figure 12-20
Rifleman
HOT Arizona
It's hard to tell from your photo, but it does look like you have some type of a one way flapper valve. the odd thing is i have never seen one like in your photo. Most of the one way pop it valves i have worked with have had a cage to contain both the coil spring and the check ball and most of the flapper valves have used a pig tail spring on the swinging gate unlike the coil spring in your photo.
This is probably some type of safety feature to prevent a complete loss of air in case of a major air leak in your trucks air brake system. Think of it as a duel system master cylinder like on your cars brake system. In the event that one line in your cars brake system were to get a hole in it the other independent side of the system work keep working, i think this is the same thing here.
zxmedic
Canada
Having a closer look the check ball is still there and the spring blew out as you see it. They list that check valve in the TM. I found a replacement that will work
Floridianson
2,514
Interlachen Fl.
I have also not seen this but my .02 would be it keeps the incomming air from returning to supply. It would have to exit the airpack exhaust.
zxmedic
Canada
Mind my ignorance it's the top inlet if thats the supply side I am uncertain would be part #2 on the TM pic I attached
73m819
327
gainesville, ga.
I am guessing that it is there as part of the TOW AIR system that 5ts have.
zxmedic
Canada
I have my suspicion that I was loosing my brake pressure because nothing was attached to it and it was wide open ?
Robo McDuff
In memorial Ron - 73M819
1,565
Czech Republic
Any updates and or new pics on this? I am starting to work on the MC and Air Pack this week as well and can use all input I can find.
zxmedic
Canada
My new air pack went in easy as well as the new master cylinder I'll try and take pics today but this is what the truck looks like as of yesterday lol uploadfromtaptalk1393250065752.jpg
droprat
Las Cruces, NM
My new air pack went in easy as well as the new master cylinder I'll try and take pics today but this is what the truck looks like as of yesterday lol View attachment 479762
Trying to troubleshoot my hard brake pedal issue. I removed valve at rear of air pak and manually added air. All sounded and appears normal. When I removed air line that feeds rear of air pak there was no air. I followed line to Air Pak check valve assembly and adapter and suspect it may be it. Where did you get new check valve?
Thanks
Rich
zxmedic
Canada
Hi Rich I went over to kenworth and brought the old one to match it up you will have to adapt but still works .Any commercial vechical shop should be able to help you out .
