Repower project for deuce get underway
Warthog
241
OKC, OK
I know.... It is one of those early '80s GM converted 350cc gasser engines. ;-)
m-35tom
226
eldersburg maryland
yes, we have a winner! the 9.0 was in fact a converted gas engine and had a few problems, all of which were corrected before IH quit making them. they never came with a turbo so were very low on power. i added piston cooling jets and expect to run 8 psi boost. this looks to be a long term project but i hope to have it done for next years rally at aberdeen
Jeepsinker
467
Dry Creek, Louisiana
Ok cool, so I have to ask now. What is your reasoning for this particular choice on powerplant? Just something yo wanted to try out? Had it sitting around? Does it have a high torque curve compared to some other comparable but more expensive engines? Just curious as to why you chose this somewhat obscure engine.
m-35tom
226
eldersburg maryland
ok, the 3208 is just too much engine plus the fuel knock and ringing in the block made hearing protection a must. i reasoned i needed a little smaller engine but thought the 7.3 might be too little. the 8.2 detroit was considered but i like strange over common place so here i am. the 9.0 looks to be a very sturdy engine despite all the bad press people gave it about head gaskets etc. someone had recently put gaskets on this one, but it took .004 off the heads and .004 off the block to get it flat again. for a diesel, that is huge. if people just put gaskets on them, no wonder they failed again in a relatively short order. torque and hp are low for the size of the engine and it is oversquare design, but i think some low boost pressure should use up the wasted fuel and raise hp 40 to 50.
Jeepsinker
467
Gotcha. I knew you had some sensible reasons, just wanted to hear from you what they were as I know absolutely nothing about this engine save from what I've learned in this thread so far. What drove you away from the 8.3 cummins? Had to have a V8? Hehehe
m16ty
218
Dickson,TN
I guess I'm just the opposite of you, I despise V8 diesels. I just like the long stroke most in-lines offer and they seem simpler to work on. Not that I wouldn't own one, I just avoid them when possible.
I'm glad you didn't go with the 8.3 GM. I've had experience with a couple of them and they were always problems. I also believe a turned up multifuel would out pull one.
A 3208 kind of gets a bad rap IMO. People call them throw away engines because they don't have sleeves but they seem to run for a long, long time before they are "thrown away". I think they are around 180hp without turbo, I would think that would be about right for a deuce. You're right about the loud fuel knock though.
m-35tom
226
eldersburg maryland
when i got my 3208 it was a rebuilt engine that was completely worn out with 8 broken pistons. bored it .030 over and put a cam in it and it was good as new, 200 hp, it was just way too much power for a deuce. it was common for me to start out in 3rd gear since it had 650 ft lbs torque. top speed was 74 mph, was happy at 68.
Jeepsinker
467
Wait, wait, wait.... Hold on here... You spent four years looking for an engine, you are the transmission guru here,... And you just now found that you need an adapter ring? Come on Tom! You're slacking!
m-35tom
226
eldersburg maryland
ha! yeah i know, but i have projects to last me another 30 years!! i also still need turbos and some other easier stuff. this will no doubt be a longer task than most of my projects.
