HDN
- 5,392
- 113
- Finger Lakes Region, NY
Dataplates.net is out of Missoula Montana, I've never met the man in person.Love the t-shirt launcher idea! How far from Hattiesburg is your friend? Would love to talk to them maybe visit and look at it if able.
Thanks! Your info was very helpful in making this happenThat looks gosh-darned good! What does the back side of the main housing look like? Did you print in bosses for drilling/tapping to screw on the base plate?
Ooooo the FedBizOffice... You're giving me ideas!I can't believe I never posted internal photos.
The side wall thickness is 0.1715"
Corner bosses are 0.654" radius from the exterior corner radii.
Hardware 4each 1/4"-28 x 3/4" overall countersink machine screws.
In order to use your CAD to make burnable string patterns for lost wax/investment cast aluminum housings (maybe you'll bid on an FBO.GOV contract to mfg them?) that internal core that forms the cavity has to have the same 5 degree taper as the outside so the wall thickness remains uniform and the 5 degree draft allows the core to be removed from the casting mold.
The core itself gets destroyed when you remove the casting from the green sand, not reusable.
Black rubber/neoprene gasket 0.046" thick.
