Request for Assistance - Front fender bracket
Kloakndagr
On The Road/California
I'm trying to replace a bent passenger side front fender (vertical) bracket on my m35a2. Can someone enlighten me on how to remove the top two bolts/nuts. I cannot figure out how to access the top of the bolts. Thanks in advance.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The correct term is "caged nut". If you decide to fix what is broken and need to look for replacements.
brianp454
11
Portland, OR
I haven't removed these myself, but as M-1028 suggests they appear to have fixed nuts below the cab floor. Have you tried running a long extension up to the screw heads and give them a twist?
Chevracer87
Hilliard Ohio
If I recall you can get to the middle of the three cage nuts by going through through the vent. I believe I was able to get a pair of vice grips on it enough to hold it while loosening the bolt. ImageUploadedByTapatalk1376454441.318235.jpgImageUploadedByTapatalk1376454320.175030.jpgImageUploadedByTapatalk1376454367.420693.jpgImageUploadedByTapatalk1376454387.854635.jpg
M-1028
Sealy, Tx
I know all about these suckers. One of my trucks snapped the bolts right off, the other was done previously and someone welded the bracket on. My current truck was untouched and I left it that way.
