Restoration of M43 by first time MV buyer
Torisco
65
Bishop, California
Coming up next
Soon to follow is cab prep for paint and cab accessories
Cutom siren install with custom timed siren relay
Weld repair of storage compartment door for a lock
Weld repair of metal split at corner of hood
Pioneer rack repair and pioneer tools refurb.
Solargizer roof installation
Then the exterior paint prep will begin.
90% of the mechanicals were done before all else. New brake shoes, wheel kits, master cylinder rebuilt, brake lines replaced where needed, Xfer case all new seals, oil pan and lifter cover gaskets, oil sending unit, new oil filter lines, new thermostat, flush and replace all fluids in differentials trans and xfer case. New fillter and oil in engine, air cleaner cleaned and new oil, Radiator check flush and re anti freeze. Heater high low voltage control board installed (drops the voltage for low speed increases for jigh speed) Installed flashing red light in grill front with relay (fused circuit) Repaired spotlight and rewired circuit. Lubed all zerk fittings (chassis) repaired emergency brake assembly, installed new throttle cable, installed new flasher and turn signal assembly. Rewired for turn signals, changed all fuel filters Replaced burned out bulbs, Installed missing bumper brackets, installed missing wheel well covers, installed clutch, brake, gas pedal and shifter boots. New shifter knob installed, repaired the horn. 70% undercoating completed, replace oil pressure gauge, replaced speedometer cable, replaced radiator cap chain, new rubber tips for hood rods, New rubber insulation for windows, wiper on off valve (vacuum) Two new ventilation exhaust blower motors (rewired new and fused), replaced missing seal / cover remover bolts on all four wheels. Installed a 24VDC jumper cable connector outlet (drivers side per TM), front timing cover seal and gasket, fuel pump and much much more.
I have one minor oil leak that leaves drops in the driveway after drving around that I have to locate and repair.
Torisco
65
Bishop, California
The siren install is not mil-spec. I wanted a siren, but I did not want the big federal fender mount type so I make my own
mounting bracket, relay assembly and mount location on the front of the ambulance.
zout
155
Columbus Georgia
The addition seems to be what you wanted on it and that is the way it should be.
Thanks for keeping the progress coming on the pictures.
If you see a 43 running around it is probably mine that got obsoundered with here about a month ago - it was blind thievery. Can you believe the culprits loaded it up in broad daylight and took it. Had to have had help - its more than a one man job - probably a whole gang of culprits.
What you going to go after next on it ?
Torisco
65
Bishop, California
I am doing accessories now. Finishing painting the cab interior, labeling the instrument panel and all accsseory switches, adding extinguisher, document trip pouch, emergency road reflector kit, plasma bottles, etc.
Also getting outside ready for painting. Thank you for your interesat. and I sure am saddened to hear about your 43. I think I would have gone ballistic!
zak
-4
Ortonville, Mi
Did the rear interior come painted white from the factory or was it done by the military? My white was pealing like a old house. There was a base layer of OD. The paint was almost non existent in the bottoms of the storage bins.
Torisco
65
Bishop, California
In all the research I did (for the U.S. Army only), and in the answers to my questions on SS regarding the paint color for the rear of the ambulance, I arrived at the following;
The Military specification says you may paint the interior olive drab (the OD. shade for the era of the vehicle), white or sea foam geen (depending on the vehicle era). They left the final decision up to the individual units. There was a stipulation that the interior of the rear doors had to be the color of the exterior (olive drab for the army). I believe this was done for tactical reasons in the field.
So, the choice of color is yours depending on whether you want to be exact to the vehicle era or not.
As far as the factory goes, I do not know what color the rear patient area was when delivered to the particular branch of service. My guess (and only a guess) would be white or blue for the air force, white or gray for the Navy. and white or O.D. for the Army and Marines.
I used Sea Foam Green Mil Spec acrylic enamel that I got from a local auto paint dealer who was able to get it for me. This color was used alot for the interior of armoured venicles like the tank, APC, and others.
zak
-4
Ortonville, Mi
Thanks, the way the paint was pealing I didn't think it was factory applied. I haven't seen one in sea foam yet, it could be a good choice.
zout
155
Columbus Georgia
Torisco - do not take this the wrong way - its not meant to be harmfull.
When I got the 109 - sea foam was in the interior and I could not get rid of it fast enough. It gave me the creeps and made me wanna puke everytime I looked at it.
When I sandblasted the back of the 43 I saw no removing evidence there had been seafoam in it under the layers. If I were a momentary patient in the back of one and it was painted sea foam - I truely believe I would have to slit my throat as it would make me nausiated.
I am color blind - but I can sure as heck figure out this color for some reason.
I see absolutely no reason NOT to paint the rear if that is what you want and more power to you - go for it. The white that was designated for the square on the red cross that coordinated with the od and also the specific red. I just decided to use the same white on the interior - just looks more hospital like.
Torisco
65
Bishop, California
I have attached some info on the Sea Foam GreenNil Spec. color.
The acrylic enamel is so expensive that I got the smallest amount (1 quart)and had the color matched in an enamel by a paint color machine at the local True Value.
If you ar enot a purist, that is the way to go for Sea Foam Green. (I still have the formula for the True Values Paint I purchased)
Good luck on what ever you decide to do.
Torisco
65
Bishop, California
I really was perplexed at what color to use. I chose the sea foam green because the white got dirtied up so fast and any nicks or scratches really showed up.
As I remember, I questioned myself about whether I liked that color when I was in a Army Hospital in 1962. The interior was a minty green similar to Sea Foam Green
Torisco
65
Bishop, California
FINALLY, PREPPING AND PAINTING FOR EXTERIOR FINISH. I am not after a glass like finish and am using 24087 semi gloss as the finish color.
Torisco
65
Bishop, California
MORE OF: FINALLY, PREPPING AND PAINTING FOR EXTERIOR FINISH. I am not after a glass like finish and am using 24087 semi gloss as the finish color.
