JeffAS
- 0
- 0
- Lessburg/Ohio
Is there a right and wrong way to start a deuce
What?Don't do it like I've seen GL guys do it....throttle to the floor, when it fires, stay at 2000+ rpm for 5 mins to get the air pressure up....
He mentioned the wrong way in his thread title. My example would be one of the many wrong ways. Start it, let it idle for 5 minutes, and be easy on her till shes warmed up. If your going to let it idle for more than 5 minutes, bump the hand throttle to >1000 RPM after the initial 5 minutes. Before shutting it down, let it idle for 5 minutes.What?
Like others have said please read the manual.
Right and wrong are moral issues. Many on this site won't have a clue. The TM is a good source for the correct method.Is there a right and wrong way to start a deuce
I was thinking the same thing, I do it most of the time !Can't believe that no one said that you crank it with the fuel shut off and check to see if you have water in any cyl. that would produce hydro lock and break something.
Let me introduce you to a concept called a "joke".What?
