Rim and tire set up
M1009
Phoenix/Arizona
I have 35's on mine and they work great! with a six inch lift... does not bind or rub, they are on 15 inch rims. I have chewed thru these tires over the years so i have some TOYO open country Muds on order I ordered them 6 months ago still not in! - very hard to find tire, I know this because my father in law is a TOYO wholesaler.
CPAPPY
Xenia , Ohio
its not a cucv but same idea. this truck has a cross over steer conv. 39.5-18-15, 12in spring lift and i beat the snot out of it. no frame cracking problems yet. I am NOT saying it dosnt happen but if you run a 12.50 wide tire and arn't hard wheeling i think you will be fine as far as the frame goes.2cents
Great looking truck . I wish I could explode the view to larger picture .
Thanks anyway.
CPAPPY
Xenia , Ohio
I'm running 15/42/15 super swampers. Anyone who says the 6.2 is way under powered with big tires doesn't know what they are talking about. Its all about gear ratio and how to use it, wheel speed isn't everything. 4 low makes it a whole different beast.
Sounds great ,do you have any pictures. And how much trimming did you have.
CPAPPY
Xenia , Ohio
Nice photos ,what size tire are those.
jimmy-90
Haymarket Va.
Figured since you asked what kinda tires we run on our trucks id put up a couple pics of what I have on my civi truck. These are Denman Groundhawg 2's. They are directional terra tread tires like you would expect to see on machinery like back hoes or bobcats. Even though they look very aggressive they ride very smooth and quiet since they are radials and not bias plys. They don't sing or roar at all. You don't seem to see alot of them around anymore but they are still available. I used to use the truck that they are on to commute about 100 miles a day with no problems. They are very street friendly unlike swampers or boggers. they ride more like all terains. I've also had good luck in the mud with them since they dig really well and make alot of foward thrust. I would have to say that they are the best mud tire I have ever owned. The only draw back is the price. The radial groundhawgs are insanely expensive compared to bias ply mud tires. But like with everything else you get what you pay for. If you don't mind the rough ride and short tread life they are available in bias too for alot less. The tires in the pics are 36 X 14s and the rims are 15 X 10 extreme steel type 51s
ODdave
41
lansing michigan
the 12 bolts where recentered with C&M centers welded in them. I have the same tires but in a 36in on my m37 and i love them. mainly plowing snow and in the dirt (not a ton of road time) but they are sweet off road. Buddy of mine had the 37's on a 94 dodge and they whern't to bad on road as far as noise. Its hard to say how they handeled, ya know it was a dodge hehe..
CPAPPY
Xenia , Ohio
Do you just cut out the old and weld in the new center . Or is there there other maching you have to do . Do they run pretty true .
True Knight
179
San Pedro, CA
I'm running Nitto Mud Grapplers- 37x13.5r17 with a 4' lift. The rims are Moto Metal. I did install a steering crossover so that i could get lock to lock without rubbing, and cut a little off the fenders so the tires would clear those too.
