Risks of driving without one drive shaft?
erasedhammer
61
Maryland
So I am having my front drive shaft lengthened at a shop, and they said to come pick it up today. Problem is I don't have a vehicle that could carry it, so I would be driving the humvee down there in high lock to pick it up and install it.
I've had to drive in 2 wheel drive once before when my half shaft gave out, but the drive shaft was still connected in that case.
Anything I should be aware of when driving in high lock without the front drive shaft? Seems like it shouldn't be a problem.
TOBASH
3,903
Brooklyn, NY
Someone please correct me if I am wrong but I thought high lock activated the front drive shaft.
I think this is a bad idea. I believe you need to use another setting on the transfer case that does not engage front axles, or you can spend $50 and rent a car for cheap and effective insurance against damaging your HMMWV.
MHO-YMMV
erasedhammer
61
Maryland
MHO-YMMV
high lock locks the normally open differential in the transfer case. Theoretically, if there is no front drive shaft, and the transfer case is in high lock, it will drive both front and rear output shafts equally, but since there is no front shaft it will just spin the output flange.
I'm just a little concerned about what happens with the torsen when there is no input shaft (a input load).
bobwire
Satellite Beach Florida
I have been driving around like that for a couple hundred miles now. I cant see what issue there would be with the front yolk just spinning with no shaft hooked up while in HL.
High Lock is the only way it will work with the front shaft out.
erasedhammer
61
Maryland
Cool, thats what I thought. Just wanted to see if there were any differences between that and running with a broken half shaft.
NDT
7,276
Camp Wood/LC, TX
Back in the day we would buy M880s with a similar full time transfer case, of course DRMO would bend the rear driveshaft by forklifting, we would pull that and drive home using the front axle only.
MaverickH1
Roanoke, VA
This information is false --> 2006 Hummer H1s with the Duramax had a 2WD position on the transfer case and I believe they still had the same diffs. Free wheeling the front diff didn't seem to be a problem to them. <---- This information is false.
However, it's possible the diffs were different due to TT4 and the mandated ABS systems starting in 1999.
Edited: Because I'm wrong and I should feel bad.
bikeman
503
Ft. Bragg, NC
Moved some while in service with only one drive shaft. Especially the Brigade S-1's truck when it dropped the rear drive shaft the night before a major exercise.
Action
1,564
East Tennessee
I don't see the 2wd option on this Alpha shifter???
http://image.trucktrend.com/f/9881752+re0+ar0+st0/0608dp_07_z+2006_hummer_h1_alpha+shifter.jpg
The H1 / HMMWV wasn't designed to be a 2wd vehicle. Some do a mod for that, though.
CRCAWC
Forest City, PA
My front left CV axle went today and the knuckle popped out of place, tore the boot and the axle contracted. Can't go anywhere in H now. But in HL, that axle doesn't engage and everything seems normal for HL mode. Reverse works fine too in HL mode. Have to drive it a short distance on a muddy dirt road, possibly a few times until I can get the parts in and change it out. Will it cause a problem?
Mogman
10,382
Papalote, TX
That should not be a problem...
Mogman
10,382
Papalote, TX
DO not drive it with a bad half shaft, period!! it can "get loose" and do allot of damage
