Roar in engine
twright
Rockmart Ga. 30153
I have a m1009 runs great But now makes a roaring noise like a alt bearing when you slow down. I puller all the belts off to see if was the water pump,alt. or the power steering . At idle roar speed it up it stops the roar. I also checked the starter to see if it was loose. I have never had one to do this any ideas?
AEC Wright Retired.
twright
Rockmart Ga. 30153
I have this cucv for about 4 years it stills runs great no skips shift great .I will check the balancer if that is ok I will take it down to the shop and put it on the rack and see if I can see what it is
AEC Wright Retired
1,814
Mine gets a roaring sound when the air cleaner is loose. Tony, are you going to bless us with your presence at the GA RAlly this year?
