Rod bearing TM help please
Boatcarpenter
17
Marlborough, NH
I've found it before, but can't seem to find it again. Need to find TM section with allowable rod bearing clearances etc. for LDT 465-1-c, 6/85 manuf. date.
Thanks,
BC
M543A2
10
Warsaw, Indiana
Rod bearing diameter clearance: .0014-.0044
Main Bearings diameter clearance: .0018-.0048
Crankshaft journal diameter: 3.6210-3.6220
Crankpin diameter: 2.9970-2.9980
Valve tappet gap: IN .010 EX .025 cold
Compression at cranking speed: 300-350 PSI normal 25 PSI variation allowed
Regards Marti
M543A2
10
Warsaw, Indiana
Further info if needed:
Maximum running clearance for rods: .0065
Main bearing maximum allowable clearance: .0068
Main bolt torque: 135 to 140 ft/lb
Connecting rod torque: 115 to 120 ft/lb
Crankshaft end play: .010-.014 max allowable .018
Main journal and crankpin out of round or taper: .0005 max.
Connecting rod side play: .007-.013
Flywheel capscrew torque: 115-120 ft/lb
Regards Marti
M543A2
10
Warsaw, Indiana
The motors were built by White, who also put them in the 2-135 and 2-155 farm tractors. We have always used the Implement & Tractor manual for the rebuild information for all of the engines in our trucks regardless of the maker or year. We have torn down, checked and re-assembled or rebuilt several motors with these specs with excellent success. The military sends the same specs of these kind to all makers so they do not have parts interchangeability problems.
By the way, if you find one of these tractors in a salvage yard, you can take the oil filter assembly off the motor and put it on yours, giving you the spin-on filters. We typically pay about $60 for the assembly less the oil cooler.
Regards Marti
