roscommon conversion Question
Brogman
Noblesville, Indiana
Roscommon Conversion Question
This is well written, But? Step 9 has you disconnect the two alternators from the 12 volt junction block. On the single Alternator option how does the Alternator connect and still charge the system? I assume it is connected some place else in the system.
rsh4364
15
greensprings ,ohio
It sure would be be nice to see a charging diagram for how this works.Like the ones in the stickies for the factory setup.My brain gets very small when it comes to electrical.Looking at the diagrams for the original set-up I can almost see how the conversion works it but Im missing something.
Warthog
232
OKC, OK
it is connected to the old 24v buss bar behind the rear battery. It is now your 12v charging point.
I Have never thought about making a wiring diagram for the Rosscommon conversion. I'll see if I can make something for the stickies
