rotating drawbar ring on m105a2
sweet trav
oside, commifornia
anyone done this? if so, can you offer some helpful advice? The main reason for wanting to rotate it is to increase the front trailer towing height and level out the trailer.
Thanks,
T
Floridianson
2,501
Interlachen Fl.
Thanks,
T
Heard that it can be done. Looks like you just get that nut lose rotate then tight retighten. I would like to do this myself so I'm hopeing it can be done that way.:driver:
mistaken1
Kansas City, KS
Been done many times. Search recovery threads.
After loosening the nut hit it straight on (front to back) with a BFH. I am talking a 12# sledge hammer not a drilling hammer.
sweet trav
oside, commifornia
um, yeah. I thought is wa scalled the drawbar ring (manual term). I was told that I might have to heat it (to make the housing expand) up once I've removed the pin and nut.
sweet trav
oside, commifornia
sort of confused by "front to back" phrase...that sound like it sould go in the direction of the rear of the trailer...don't you want to hit it towards the front?
Barrman
1,740
Giddings, Texas
Hitting the lunette side to side will also break the cone fit loose. BFH is your friend. 1-1/2" wrench is what you need for the big nut on the lunette by the way.
amaverick88
Bonaire, GA
if it is like the one that i helped change on a 105 it may be easier to keep the nut on the threads on it hook it up to either a tractor or a tow vehicle and shake the lunette ring loose. it all depends on how tight the lunette ring is or how long it has been since the last time it was turned.
mistaken1
Kansas City, KS
What I have found is after loosening the nut hitting the lunnette on the front (ring) driving straight into the frame (towards the back) seems to loosen it the quickest and easiest.
Barrman
1,740
Giddings, Texas
It all comes down to this. Get the nut loose and commence to beating on the thing with the biggest hammer you can pick up. Once you get it apart, clean the inside out, smear grease everywhere, flip it and tighten the nut back up. It will come apart with no problems for the next few years now. Then it will be BFH time again.
Rthomas
Jena,La
I used a pipe wrench and a cheater pipe to break the nut loose. Then I chained the trailer to tree and the lunette to a tractor and it did not come loose. Hitting it dead on is the best way to remove it and it will fall out.
wikallen
IA
mistaken1 is absolutely correct. Loosen the nut, then take a full size sledgee and hit the tip of the ring in towards the trailer. Then hit the top of each side to try to rotate. Rinse and repeat. Keep doing this and it will eventually pop loose.
Pulling it down the street with the nut loose, hydraulic porta power, heat, all failed in comparison to 1,2,3 (hit in, hit top left, hit top right) over and over.
