rough starting m1009
nighttrain2006
park forest ill
when i picked up the m1009 it started fine
now it starts then dies right away, then doesnt want to start again u really have to crank it to start it.
i change the oil, air and fuel filters
plan on buy new plugs and fuel pump
any ideas on what the problem mite be
Rebelpride
Thomasville, NC
You probly got air into the system when you changed the fuel filter. You will need to crack the bleeder on top and crank till fuel squirts out. This requires 2 people. Then it should crank, run rough for a bit then smooth out.
trkosaur
austin, tx
I had the exact same problem. Starts right away, dies. It usually takes two sets of good cranking with the pedal down to get it to fire after that.
I did two things and she fires right up now. Changed the fuel filter and bled according to the manual. I am pretty sure that I had a bit of air in the system which was causing the whole problem.
Also, I cleaned the plunger that sits right on top of the injection pump (looks like a screw sticking out). Make sure it can move easily as it is directly related to your throttle and can get stuck easily.
Seemed to work for me, hopefully this helps you out.
