Rough sway bar dimensions
Awesomeness
1,518
Orlando, FL
I just got an email from someone who was thinking about putting an LMTV sway bar on his F350. He wanted some rough dimensions, to know if it will fit. These are just some tape measure measurements (e.g. +/- 1/2"??), without really crawling under there, but just in case someone else wants to think about this in the future, here's the answer.
Bar is 2" in diameter.
coachgeo
3,461
North of Cincy OH
since we are talking ruff measurments.... @Awesomeness or anyone else that knows something on this question; what do you think would be a good choice in Shore # Pourable Polyurethane to use to refill the end bushings (#12 in image) on these? 60A? 80A?
Awesomeness
1,518
Orlando, FL
since we are talking ruff measurments.... @Awesomeness or anyone else that knows something on this question; what do you think would be a good choice in Shore # Pourable Polyurethane to use to refill the end bushings on these? 60A? 80A?
The originals are 80A. Aftermarket polyurethane bushings (e.g. Energy Suspension) typically stiffen that up some. I use 90A for my sway bar bushings. (Most of this was described in my sway bar bushing post, I think, in more detail.)
60A would be way too soft. Also, the softer they are, the lower the tensile strength, generally. So you get your toughest materials at the harder range.
