- 523
- 44
- 28
- Bishop, California
I have acquired a RT-12/TRC-2 labeled radio that appears to be complete and in really great condition. In researching what I need to see if the radio will work I received the following information
"Take the Receiver out of the chassis and look for a small battery colored green, that is either a plug in (late) or wired in (early). This should have a voltage of 4.5 volts on it. if it does not it MUST be replaced as it runs the audio output section and if it is not at the correct voltage it will cause the output transformer to burn out!!! There are NO known replacements for the transformer so you have to find another Receiver and swap it out to fix it!!!"
My problem, is that I cannot locate the wired in or plugged in battery on the receiver of this radio. I have "TM 11-4015, Receiver -Transmitter RT-12/TRC-2, Repair Instructions" but still cannot locate the exact position of the 4.5 volt battery. I have the parts list for the receiver and none of the parts are marked 4.5 volt battery. Any help would be greatly appreciated.
