SSG ALBANESE
- 1
- 16
- Monterey, California
Hello Everyone,
I am stumped, my M1008 has more issues that I care to admit too. Here is the break down.
1) Starting system:
For the second time the truck will not start, it acts as if i need to tap the starter with a little hammer love tap. With the ignition all of the way off and key out the starter stayed engaged on the flywheel preventing the truck from running.I disconected the batteries to save the starter (killed the starter solinoid though). CUCVelectric helped me find that it was the starter relay under the dash above the 4x4 shifter. I replaced it with the HD relay recommended. Also had the starter (new gear reducted made for the CUCV - not stock but still 24V). It ran good for about two months - if that.
Yesterday I stopped and turned the truck off. About two minutes later I jump back in and try to start. No crank. I get out again to love tap it with the hammer but before I could get on the ground the starter starts spinning, with my broken leg in a cast I couldnt get under the hood to the batteries fast enough so when I opened the hood the smoke of the cucv gieny was already in my face. Starter relay? what would cause this to keep happening ( the relay never smokes nor smells of burning).
Anyone know what could cause this or what I should check for? Thank you.
2) Blinkers:
Will blink if I finger the lever : ) but not automatically. I have replaced the flashers, checked all bulbs, replaced front running light sockets. Any ideas?
3) Horn:
Horn didnt work. I tested the horn it was bad, I replaced it... no honk honk sooo I replaced the bad fuse (checked the rest of them too) then the horn decided to start blaring on its own. I had to remove the fuse again.
4) Glow Plug system:
Crap lol I will get into this later after I can get some help on the other stuff.
Thanks everyone, I look forward to your knowledge.
1) Starting system:
2) Blinkers:
3) Horn:
