Robtstee
- 12
- 3
- Orlando, FL
Have a 1028. You know the story, all was normal, hit key to start, starter kept going. Proceeded to freak out mode. Luckily had a full toolbox in the bed, ran and pulled both battery cables within 20 seconds of each other. Went to check underdash relay. I had already done the replacement and it works fine. Gen 2 light doesn't come on and I've got some fusible links to replace.I have the Hillbilly gear reduction starter. Figured it was a stuck solenoid, pulled it and no continuity across the poles. Not really familiar with the solenoid operation. 1st question is, why would the solenoid test open dismounted and closed when mounted? I did take it apart and saw nothing out of the ordinary, burns etc.. 2nd question, anything to look for on the starter before I put it back in? Please assume I know absolutely nothing in your replies.
