running a multi (LDT) w/o fan and or radiator
move it w/ no radiator?
  • complete install first
    Votes: 6 24.0%
  • just install the radiator then move
    Votes: 5 20.0%
  • move it before installing the fan/ radiator
    Votes: 14 56.0%
BFR
Rocket Surgeon
2,330
42
North Georgia
I have pulled the radiator and fan from my deuce so I can have the radiator repaired. It worked out that I was able to pull them in daylight, but I may not be so lucky when I go to reinstall. Where the truck is sitting I have no access to electricity, but if I move it a quarter of a mile I can have power and park under some nice flood lights.
So...
would completely reinstall where it sits,
just install the radiator & add coolant then move it,
or
move it first and reinstall everything after.
1,176
Flashlight?
1,807
I've ran my crane without a cooling system for 10 minutes at a time before. Just remember how long it takes to bring them up to temp. Can you run the distance at 1000 RPM in say 3rd gear? What is the ambient temps outside? I don't think it would be a problem but your mileage may vary. PS, I've ran canned motors that long as well and you could still touch the cylinder heads with your hand.
ctmustang
Thomasville-N.C.
By all means yes. You can safely drive the quarter mile without the coolant system intact. Just drive it normally and get it to where you are going and park it quickly. I've been in the heavy mechanic business for 24 years and have done similar so many times.
CT
NDT
6,342
Camp Wood/LC, TX
CT
Let me make sure I understand, it is OK to run a truck 1/4 mile with no water in the block whatsoever? It won't warp?
1,807
Takes a good long time to get them up to a mere 100 degrees. Truthfully you could probably run it with no load for 30 minutes without getting it very hot.
1,128
But what about the water pump bearing?
derby
10
S.E. MI.
:ditto: That is what i was thinking. cheap insurance. It might be ok to run it without the radiator but I would hate damage something else.
scrapman
deland florida
Start it, light on the throttle, short shifting to get to 3rd gear quick, don't rev much past 1500rpm and you're done in less than 7 minutes. And where you are at the temperture has chilled that big chunk of cast iron motor through & through.
Keith_J
1,318
Schertz TX
Connect (short cut) both radiator hoses temporarily, fill it with water as much as possible and drive 10 miles or more if you had to.
G.
Exactly! If it is under 50 F, you should be golden, just watch the temp gauge! Direct injected engines have the most heat in the piston, the heads are relatively cool. And no full throttle, at part throttle, there is little heating.
JAYHAWK 1962
tijeras, nm
Ditto, interesting thread. They taught us the two easiest ways to kill an engine is to run them, 1) without oil,
2) without coolant.
Personally i do not think i would risk it with my vehicles.
Just my opinion. Thanks
Stan Leschert
90
North Vancouver, BC, Canada
When running demollition derby we did much worse. That being said, while anything can be possible, a lot of things are not advisable. It is your investment, so it's up to you. If you really must move the rig, reconnect the rad lines, refill the coolant and keep a very close eye on the temp gauge. Remember, that gauge only works when it has fluid in the system to measure. Borrowing a flashlight or a Gen Set is a lot cjeaper than doing a main power pack Re & Re. Git Her Done would not be the wisest of options here, but it's your money,
rosco
Delta Junction, Alaska
You can drag it to where your going with a pickup. Your going to have hot spots in the engine. Besides all that stuff, your going to loose stuff and it takes time to move the stuff/tools/bolts off the fenders. Get a coleman lantern and put it back together. You'll be done in an hour! That will take less time, then moving it. A radiator is nothing!. I replaced a broken valve at night, along the road, at 0 degrees, holding a flashlight in my mouth. Just go put it together!
Lee in Alaska
