jasonjc
- 291
- 83
- Gravette Ar.
I moved my M36 5-6 time with the rad out. And it is just fine. a little short move like that should be fine.
Flashlight?
I'd always understood gasoline EGT to be higher than diesel. Also keep in mind that the diesel is taking full gulps of cold air whereas the gas is not.BE careful if you run the truck for more then 6 minutes a Diesel will start to burn up without the coolant in the engine !! A diesel is a compression ignition and it burns hotter the a gas engine and it does not take long to start to burn !! I would do like Heavy Steven said get a someone with a tow bar !!! no sense in burning up your truck's engine
