Tjblanchard
- 0
- 1
Guys,
I been having issues with the 3 lever light switches. I've changed out 3 in 3 years. I finally took one of the bad switches apart and basically could see where the switch had burned. Any way, i took all the guts out the 3 lever switch and added seperate switches for my signal lights and brake lights (Which works great) and one for headlights and running lights. I have headlight but no marker or front and rears lights. I've check that i have power going to the correct wire (L) but i can't find power at the light themselves. My question is there a plug somewhere in the harness that could have been unplugged? Everything i've read says all the lights i'm having problems with run on one wire (21).
Any help one this would be great.
