Running lights
Masspilot
Ky
So Been working on the truck and for some reason the running lights are not working installed a new fuse the other one was popped. As Soon as I put in the new fuse it blew again. I read marks reply about the cover and that's not the issue my cover was off at the time it blew. Anyone else have this issue pls advise
NDT
7,498
Camp Wood/LC, TX
Check the wires that go through the door jambs for crushing or exposed conductors. You have a short circuit and that is a likely spot.
108
Central california
We recently removed all the lights from our LMTV (head lights, stop lights, marker lights, all of them) and fixed whatever needed fixed. Some of the lights had water in them, some of the wires were crushed and grounded out, and some of the bulb contact were so corroded, that they weren't working any more.
If your fuse is popping, you might need to hunt around for problems like we found.
Michael
