Rust proofing & protection
Unionjackjim
Kent , UK
Just a thought .
As the chassis rails are open either end & are sealed front to back , how do you guys get the water & sand out of the chassis & rust protect , to prevent internal corrosion .
answers on a post card :?
86humv
487
Texas
They drilled holes in lower section of frame.....one forward, and one aft.
I saw a frame this way with 1/2' holes.
Mine had the holes, so I washed it out with a hose / water from the front , and from the holes....washed out some dirt and stuff.
86humv
487
Texas
The A2's have small drain plugs/screws on the lower inside frame rails, and the front of the rails have blocking plates.
