Rustproof your bed
littlebob
26
Baton Rouge LA
If you thin the bedliner stuff per the instructions you can spray it from a paint gun with a larger bore nozzle. You can also mix colors into some of the liners. Years ago, I saw a brand that you could purchase in any color imaginable. I wish I could remember that company...
I've heard the same thing a few years ago from a guy that custimized trucks.
He said he bought a special gun and they could mix any color like paint. I think he was getting his stuff from Carquest parts/paint here in town
The system I am using here in Florida seems to work well. After the rough scraping, wirebrushing, then blowing off everything with compressed air, I brush on Jasco Prep & Primer. It has the Phosphoric acid used to convert rust from ironoxide to ironphosphate, which is the black/blue paintable surface for which you are looking to keep it from rusting or bubbling in the future. After a 24-hour cure, I scrub it down with scrubbing pads and a strong base solution of 1:10 ratio heavy-duty degreaser from Sam's Club.
After that dries, I either prime it with rustoleum rusty metal primer and then paint it, coat it with bedliner, or in some cases use undercoating. The main product I guess I am recommending is the Jasco Prep & Primer. You can get a quart-sized bottle from Lowe's for about $10, and that would be enough to do several deuces. I think the last bottle lasted me almost 3 years. It has the viscosity of water, and brushing it on very lightly will do the job.
Seth_O
Sac CA
Has anyone ever tried Rust Bullets. I've heard it's good but haven't talked to anyone that's actually used it.
I used RB on my Landcruiser frame. I sprayed 2 coats of the silver automotive and one coat of the black top coat. I used a spray gun, and it went on awesome. I chose the RB because it took a minimum amount of preparation (I hit the rust/frame with an air scaler and washed it good to ensure no oil on the metal.)
I've found that the two coats of silver are holding up great. The black top coat seems to be wearing off in some of the high traffic places though (on the sliders where I climb in-n-out,) not sure if I did something wrong though.
Good stuff, would use it again, and would recommend it to anyone else.
