Overdrive
- 95
- 28
- Wentzville, Missouri
Here we go!
I am calling my HSTRU build complete so moving on to the next project.
I am putting the M1102 & S250 shelter build on hold (kid likes it for a playhouse) while I move to my newly acquired AN/GRM-86X Electrical Equipment Maintenance Shelter and M720 Dolly set. Basically it has the same dimensions and characteristics as the S-280 other than the old style door latches which are brackets rather than roller/lock. I believe it was built around 1974.
Dolly is your standard M720. Shelter weighted in at 1640lb.
Tech Note:
You can install an M720 onto a shelter by yourself with a floor jack on a concrete surface if the shelter is sitting on blocks to clear the jack
This build isn't going to be super fancy, ultra high speed like the HSTRU. Instead its purpose is for a remote camping setup to be left on my remote property in AZ so I don't have to trek across the country with a trailer to go camping once a year. Based on that it needs to be sealed up well with no holes and able to stand up to the elements and the ever persistent rodents of AZ.
Basic built-in components will be 110v and 12v electrical with 30 amp 110v RV service plug, two group 29 12v batteries, and solar for main power. Haven't decided whether or not to add a water system but I am leaning towards yes. Also adding hybrid air conditioning as well as propane furnace.
There will not be any fancy beds or cabinets made but rather using what I already have for Overland gear sitting around the workshop. Right now, I am looking at using bunk bed cots and a surplus medical cabinet that has storage and two small aluminum tables. Since I am into HAM radio now I will be including a radio setup and possibly some antenna mounts.
Current Activity:
1. Patching up two holes in the shelter skin with aluminum patches with rivets.
2. Replacing damaged rivets and inspecting for weather tightness.
3. Removing badly applied latex paint slapped over mildew.
4. Cleaning interior of all mold and mildew so it can be caulked and painted.
5. Remove and replace all 3 side hand holds (mangled) - DONE
6. Register dolly as a trailer - DONE
7. Clean, sand, and paint old rusty door hinges to see if they are salvageable.
Gotcha's or Lessons Learned:
1. Dolly vertical brackets are not lined up for M720, 5.75" too high so have to remove rusted out old brackets and replace with new in different position.
2. All three skids on the shelter are rotted steel and falling apart so they will have to be replaced.
3. A couple of holes under shelter will need to be filled and patched (lost a couple of fights with a forklift at some point).
4. Door latch mechanism mount bolts are stripped.
Here is the shelter in GL yard before I picked it up.
In transit (buddy who donated transport and time standing on the light tower)
After removing the brushed on battleship grey latex paint using non-toxic citrus stripper.
More progress and pics to follow.
Hopefully someone will find this build useful...
Cheers!
OD
Tech Note:
Current Activity:
Cheers!
OD
