S-788 shelter
04mustang
9
Lumberton/NC
Do you have a source for the center-bonded bushings used to mount the shelter to the frame/bracket? I can't seem to find them...
And have you found a good way to fix damage to the skin? I was going to just cut out an aluminum panel and rivet/cement it, as I'm guessing the skin isn't weldable. Think it would be possible to alumaweld it?
Thanks!
Brian
No clue on the bushings. But the skin is supposed to be repaired with sealant around a patch plate that is then riveted in place. for bad damages to the internal insulation they recommended filling with a similar insulation piece and sealant, then the outside patch.
